Aqara G4 Doorbell Offline
I’ve had the g4 for a few months and it has been amazing. All of a sudden the past 2 weeks the doorbell keeps going offline. Does anyone else have this issue and has found a fix?
@vega210 I’m sorry to hear that your G4 Doorbell has been going offline recently! This can be frustrating, but there are a few steps you can try to resolve the issue:
  1. Distance and Obstacles: Ensure that the distance between your G4 Doorbell and the chime is within 5 meters, and try to eliminate any obstacles between them.
  2. Power Check: If you’re using batteries, check if they are alkaline and have sufficient power. If you’re using wired power, ensure the connection is stable.
  3. Restart and Reset: Restart the doorbell by cutting off the power and then restoring it. Also, consider doing a factory reset by pressing and holding the reset button on the doorbell for 10 seconds.
  4. Wi-Fi Strength: Make sure your doorbell is connected to a strong 2.4 GHz Wi-Fi network without interference, and avoid using special characters in your Wi-Fi name or password.
If these steps don’t solve the problem, reaching out to Aqara customer service for further assistance might be a good idea. I hope this helps, and let us know how it goes!
@vega210 I’m sorry to hear about the offline issue with your G4 Doorbell—let’s see if we can troubleshoot it. Based on common solutions for this problem, here are some steps to try:
  1. Keep the distance between the doorbell and chime within 5 meters, with as few obstacles as possible .
  2. Restart the doorbell by recharging the external power or replacing batteries (if using batteries, ensure they’re alkaline) .
  3. If restarting doesn’t work, try long-pressing the reset button on the doorbell for 10 seconds .
  4. Check if the doorbell has enough power—low power can cause connectivity issues .
Have you tried any of these steps already? It might also help to see if other community members have faced similar issues and found additional fixes—feel free to share your progress, and we can troubleshoot together!
