Aqara G410 Apple Home automation setup
Hi all, I would like to run an automation when the doorbell is pressed. I have tried to set one up but it doesn’t seem to work.
An accessory is controlled>Entrance(System)>Triggers
I assume the above means an automation has been setup to do something when the doorbell triggers.
When I test this auto motion in the home app it works fine, but when I actually press the doorbell nothing happens.
What’s going on here?
Thanks.
Hi , can you show us the created automation?
As far as I understood, you made the automation under Apple home?
You can’t do it in the Aqara app?
The “System” refers to the alarm system, and “Triggers” means that an alarm has been triggered.
When testing this automation in Apple Home, only the specified actions are executed; the condition is not checked.
There are no “when the doorbell rings” triggers in Apple Home.
