I’ve been using the Aqara G410 Doorbell Camera for a few weeks now, and I’m really impressed with its performance and features. Here’s a quick rundown of my experience and some tips for anyone considering this device.### What I Love About the G4101. Build Quality and Design: The camera and chime unit are sleek and well-built. The design is modern and blends seamlessly with my home’s exterior.2. Video Quality: The 4:3 aspect ratio is a huge improvement over the previous 16:9 ratio, especially for detecting packages and visitors. While it doesn’t quite match the 2K resolution of its predecessor when used outside Aqara’s ecosystem, the image quality is still sharp and clear.3. Motion Detection: The mmWave sensor is a step up from the old PIR sensor. It’s more reliable and reduces false triggers, especially at night.4. Integration with HomeKit: Setting up the camera with Apple Home was a breeze. The integration is seamless, and the camera works perfectly with HomeKit Secure Video.### Tips for Getting the Most Out of Your G4101. Placement: Mount the camera at a slight angle to cover your entire porch and driveway. The 175-degree field of view helps, but optimal placement is key.2. Battery Life: I’ve been using the battery-powered option, and it’s lasted about 6 months so far. The battery compartment is easy to access, which is a big plus.3. Customization: The Aqara Home app allows you to set up custom detection zones and adjust the lingerer detection range. This is great for minimizing false alarms.4. Storage Options: If you want to keep recordings locally, the microSD card slot is a convenient feature. Just make sure to format the card properly before use.### Potential Downsides- Resolution Limitations: As mentioned earlier, the 2K resolution is only available within the Aqara ecosystem. If you’re using other platforms like Home Assistant, you’ll get 1080p.- Weather Rating: The camera is only IPX3 rated, so it’s not fully waterproof. I’d recommend getting an additional cover for extra protection.### Final ThoughtsThe Aqara G410 is a fantastic upgrade from its predecessor and a great choice for anyone looking to enhance their home security. While there are a few minor drawbacks, the overall package is solid and well worth the investment.If you have any questions or want to share your own experiences with the G410, feel free to drop a comment below! ![]()
