Aqara G5Pro Camera and Apple Thread Network
My cameras are connected to my Apple thread network. However they are all showing as detached and are on a different Thread Partition ID than the rest of my thread devices. Iyt would be very helpful to have these devices working as thread border routers. Any ideas ow to correct this?
I would separate the G5’s camera connection from its Thread border-router role. Aqara lists the camera’s data connection as Wi-Fi or Ethernet. Thread Group explains that the Matter ecosystem and the Thread mesh are separate, and border routers need shared Thread credentials to form one mesh. Simply seeing the camera in Apple Home does not establish which Thread mesh its radio has joined.
Which app or screen reports “detached”, and are these Wi-Fi or PoE models? Could you also share the G5 firmware and Aqara Home versions, plus which Apple border routers you have? It would help to know whether Thread accessories are actually unreachable or whether everything works apart from the diagnostic display. I would establish that before resetting cameras or changing network settings.
I have the exact same issue. All my Apple TVs / HomePods have the Partition ID 3F625E6A and all my Aqara Hubs have the Partition ID 6A5E623F. But take a very close look at the IDs. At first glance they look different, but if you look very closely, they are identical just displayed in reverse order.
3F 62 5E 6A in reverse order is 6A 5E 62 3F. So I would assume that the network is actually not fragmented in this case.
If your IDs are basically the same as mine, then the “detached” status must have other reasons. What does the Aqara Home app show you for the G5 Pro in the settings under “Network Information” → “Thread” or “Thread Network Management”?
