Hi,
I’ve used gesture control successfully before on my Camera Hub G3. After resetting and re-adding the device, gesture detection can be enabled, but gesture triggers are missing in Automations.
In Automation → IF → Device, the G3 shows no gesture-based IF triggers (sometimes the G3 doesn’t appear at all). Human Detection and Gesture Detection are both ON, firmware is updated, and the camera works normally otherwise.
Since this worked earlier on the same setup, this seems like a reset / re-binding issue where gesture automation is not re-initializing properly.
Is there a known fix or a required step after reset to restore gesture IF-THEN automations?
Thanks.
