Aqara H1 (No Neutral) – LED Bulbs Still Glowing When the Switch Is Turned Off
I’m experiencing an issue with my Aqara H1 switch (no neutral wire) and LED lighting.
I have a ceiling light fixture with 5 LED bulbs, each rated at approximately 3–4W. When the Aqara H1 switch is turned on, everything works normally.
However, when I turn the switch off, the bulbs do not turn off completely. Instead, they continue glowing at approximately 5–10% brightness.
I understand that this may be related to the small residual current required by switches without a neutral wire, but I would like to know whether there is a way to resolve this.
  1. Is this a known limitation of the Aqara H1 without a neutral wire?
  2. Would installing a bypass capacitor or an LED bypass module solve the issue?
  3. Is there any possibility of addressing this through a firmware update or software setting?
  4. Would switching to the H2 version eliminate this problem?
I’d appreciate feedback from other users who have experienced the same issue.
Thank you!
I think H2 will have the same problem. Yes, you can install a LED bypass/anti-flicker capacitor and it will help.
Optionally, you may try different lightbulbs, maybe you don’t like the white temperature, shape of them, or maybe the CRI of current bulbs is less than 90 :wink:
Hi, try disabling the LEDs on the switch. Create “light silence” for the switch.
I will definitely try it, but I am happy with my lightbulbs so far. The whole point of the smart switch was not to replace all the bulbs with smart ones.
I have the same, but only sometimes and only for 3-4 seconds, then light goes off.
The Aqara H1 (No Neutral) needs a small amount of electrical current to power its internal electronics, even when the lights are switched off.
Because there is no neutral connection at the switch, a small current can pass through the lighting circuit. Some LED bulbs are sensitive enough to react to this current, resulting in a faint glow or occasional flickering.
Your five bulbs have a combined rated load of approximately 15–20W. Although this exceeds Aqara’s stated minimum LED load requirement, the bulbs’ internal driver circuits can still cause compatibility issues
Hi,
Are the lights dumb or smart?
Thank you,
