Aqara Home App-Low Battery Notifications
It would be nice if Aqara would enable low battery notifications in the iOS App. You took the time to list all the batteries in the Consumables section but that does not really help much, what would be useful is a notification when the battery reaches 10% or something similar. You would think that would be a no brainer for a company that has so many battery operated devices.
Please feel feee to move this thread if you posted in the incorrect location.
There is a low battery notification for the device, but some older sensor products may not have accurate battery readings, so no notification is sent.
Do you know what the threshold is for sensors w/batteries? Below 10% for example? I did go back in and locate what you mentioned, thanks for the reply letting me know
What device are you using that is not receiving low battery notifications?
8 motion sensors and 8 water leak sensors, I have to use other Apps or manually check to see if the batteries are low. All the Aqara app shows is “Sufficient” which does not say much. There are numerous other ways to check the batteries which show % or even send out notifications when below a set threshold like 10% etc.
