Good morning! British Columbia (as well as several other Canadian provinces) have elected to no longer observe daylight savings time (this decision was made many months ago). The regular time change would have happened this weekend. BC is staying on Daylight Savings Time, not Standard Time (this puts us 1 hour off of our southern neighbours). Current time in BC is 10:50am (vs 9:50am in the App and in the western-most US States). I’ve tried toggling the DST setting, but nothing gets the U400 / Aqara Home app to change the time to our new time.
Submitted a bug report on this as well.
Having to manually set time zone to SK right now in AB to stay on UTC-6 (Permanent ABT time is now UTC-6)
Also filed a case to Aqara.
in Manitoba it’s UTC-5 now permanently but the App still shows UTC-6 with DST settings.
Check Aqara Home > Home Settings > Time / Time zone, rather than Profile > Settings.
Thank you for your feedback. We are working to resolve the time zone problem in these regions. We expect to have the problem you reported resolved by the end of this week. ![]()
Aqara support was in touch overnight and had me go back into the app and swap back to my city. The time zone data appears to be updated and is displaying ABT -6.
Worth checking on your own area too.
hi all, please check if this problem has been fixed in your time zone
can you finally add European date format to UK and Europe time zone?
Problem persist if you have automations that are running in the cloud. All local automations works just fine. (DENMARK)
Could you please describe more about the automation problem and PM me the automation id(which is at the bottom of “more settings” in each automation)
Coquitlam, BC, Canada - still set to GMT -7 (PDT)
Edit: Just changed my City to Calgary (Alberta) so I instead get GMT-6 (which is what PT for BC will be).
Luckily enough, Aqara is using UTC internally, so all of the logs automatically update to the correct time when you do this. ![]()
Are you sure you are doing your time zones right?
Aren’t you at -7 right now in BC permanently? PCT Pacific Time -7
Alberta stayed on the same one hour apart from you guys and we’re permanently on ABT (also known as Mountain Time) -6 now
I still have to have the time zone set to Alberta for it to display the correct time in the app. Tried toggling it back to Vancouver, still putting it an hour behind.
It really doesn’t matter if you change it in Home Settings or in your profile - it’s the same data location. (change it in one, it shows in the other).
It’s like there’s a hidden “daylight savings time” toggle that we can’t adjust, that’s flipping us back to standard time regardless.
If you are still having an issue send them a ticket, they fixed mine so quickly
It’s working fine with the workaround for now (having Calgary as my city rather than Coquitlam). Kinda ridiculous to have to contact support for them to fix the time zone for each and every city (they should be proactive and fix that themselves…they’re aware of the issue).
