Does anyone have a template of a layout for a smart home security system to replace an outdated one?
At the moment, my home has an alarm that’s disarmed with a PIN code. My thinking is this could be updated using Aqara products.
My initial idea includes:
- a way of arming it at night, likely through some kind of automation or voice control shortcut (I use Apple Home)
- triggers for entry, through some kind of door sensor
- a way to disarm it if specific people approach the house (I already have a doorbell and outdoor camera)
- a siren
It’s just an initial idea so there may be other things that I haven’t fully considered. But just wanted to see if anyone in the community has already tackled this and come up with a solution.
@james_gibbons Great setup idea — you’re thinking along the right lines, and Aqara’s Alert System can definitely handle most of what you’re describing. Let me break down how your requirements map to what’s available.
Arming at night / via Apple Home
The Aqara Alert System supports four security modes: 24/7, Home, Away, and Night. The Night mode is perfect for your bedtime arming scenario, and you can arm/disarm it through automations or voice via Apple Home integration. Running the Away alert also arms Apple Home’s security system simultaneously. For voice shortcuts, you can set up Siri automations that trigger Aqara scenes.
Entry triggers with door sensors
Door and Window Sensor P2 works with the Alert System and can trigger immediate notifications when armed — useful for detecting unauthorized entry while you’re away. These integrate directly into any of the alert modes you configure.
Disarming based on who approaches
This is where it gets trickier with pure Aqara. The Alert System doesn’t natively disarm based on camera/doorbell facial recognition. You’d likely need a workaround: geofencing through Apple Home (auto-disarm when your iPhone arrives), or an NFC tag/Aqara smart lock for recognized users. The D100 lock supports “open door with assigned fingerprint/NFC” as automation triggers, which could chain into disarming scenes.
Siren
Aqara Hub M3 (or other hubs with built-in sirens) can serve as your audible alarm, and high-security devices like smoke sensors can be configured to trigger gateway alarms too.
Quick-start path
- Add Alert System to your Aqara Home dashboard via Edit Dashboard > Home Service
- Configure Night Alert for bedtime, Away Alert for leaving
- Add door sensors to your triggered devices
- Set up Apple Home automations for voice arming/disarming
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
What hub are you planning to use? The M3 unlocks the full Alert System with cross-network support, which matters if you’re mixing Thread/Matter and Zigbee devices.
That’s great and very comprehensive for a starting point! Geofencing would certainly work and may actually be a better solution.
Thank you!
@james_gibbons Glad it helped, James! Geofencing really is a solid route for your setup — especially since you’re already in the Apple Home ecosystem.
A couple of quick tips if you go that direction with Aqara’s automation: set your home as the geofence center and give it a generous radius (500m+) to account for any system or network lag, so you’re not left standing at the door waiting for disarm. If you want the system to prep a bit earlier — say, disarm 10 minutes before you actually arrive — you can place the geofence boundary along your usual route home and estimate the travel time.
One heads-up: if you’re using Aqara’s native geofencing automation, it only triggers on the phone that created it. So if your partner or family members also need to trigger auto-disarm, they’ll each need to set up the same automation on their own devices — unless you upgrade to Automation 2.0, which lets you link multiple family phones under one geofence and even set logic like “disarm only when the last person leaves” or “arm when the first person arrives”.
Worth exploring once you get the basics running. Feel free to share how the build goes — always curious to see how folks adapt these setups in real homes
