Does anyone has the same problem, when the Night Alarm (actually any alarm that activates)is turned off Hub M1s and M1s gen2 will light up every time this happened for weeks after updated new software… any solution tho solves this problem? please help
I’m experiencing the same issues. From what I’ve found online, the common suggestion is to delete and reinstall the apps to fix the problem, but that hasn’t worked for me
@pui11 The issue has been resolved. Please try re-editing and saving the security mode configuration (e.g., adjusting the volume, trigger devices, etc.).
@djhypnotk The issue has been resolved. Please try re-editing and saving the security mode configuration (e.g., adjusting the volume, trigger devices, etc.).
I have the same problem.
is there anything else I should try? Adjusted the sound restarted each one and they still turn on when disarming every morning.
@djhypnotk @Marc3k @pui11 Please adjust the volume settings for all security modes and save them again.
Finally fixed my issue. Went into Aqara app and then hit Alarm card / section. Hit settings icon on top right. Next look for Alarm Bell Response then Alarm Sound and go to the bottom and slide the volume up and hit save or back all the way out. I use HomeKit and this wasn’t very obvious as you can tell from the prior responses.
Hopefully it helps
