Aqara Hub M2: One Hub for Zigbee, IR, and Your Voice Assistant
Category: Aqara Products | Suggested tag: ProductSpotlight
Hey Aqara Community! :wave: Whether you’re just starting your smart home or growing a big one, everything begins with the hub. Let’s take a closer look at the Aqara Hub M2.
What is it?
The Hub M2 is the control center that connects your Aqara Zigbee devices to your home network (Wi-Fi or Ethernet) and to the platforms you already use. It also has a built-in infrared transmitter, so it can run the “dumb” appliances you already own.
Key features
  • Zigbee 3.0: connects Aqara sensors, switches, plugs and more. Up to 128 child devices, with repeaters such as Smart Plugs or neutral-wire Wall Switches needed to reach that number.
  • 360° IR control: add TVs, fans and air conditioners to scenes and automations, and control them by voice.
  • Built-in speaker: use it as an alarm siren, doorbell chime or alarm clock, with configurable ringtones.
  • Ethernet port: an optional wired connection for extra stability and faster response.
  • Flexible power: micro-USB, 5V/1A, so it can sit on a power bank for backup.
  • Wide compatibility: Apple Home (including all four native alarm modes), Alexa, Google Assistant and IFTTT.
Good to know
  • It needs a 2.4 GHz Wi-Fi network (5 GHz won’t work) unless you use Ethernet.
  • Not every child device supports every platform, so check each device’s compatibility.
Idea to try
Pair the M2 with a door sensor and a motion sensor, and let the hub’s speaker act as your local alarm. Add an IR automation so the fan turns off when the bedroom window opens.
Join the conversation
How many devices are on your M2, and what’s your favorite automation? Share your setup below! :point_down:
@j86fwpr22k Hello there! :wave:
Thank you for sharing this fantastic spotlight on the Aqara Hub M2! It’s always great to see the community coming together to highlight the core of a smart home setup. :house::sparkles:
You’ve perfectly summarized why the Hub M2 is such a versatile control center. As mentioned in our product details, it supports up to 128 Zigbee 3.0 devices and offers that crucial 360° IR control to bring your traditional appliances into the smart ecosystem . The idea to pair it with door and motion sensors for a local alarm is a brilliant use of the built-in speaker feature, which also serves well as a doorbell chime .
I’d love to hear from others in the community: How many devices are currently connected to your Hub M2? And what’s your favorite automation routine? Let’s keep the conversation going! :point_down:
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
