Aqara indoor light T1
Will I be able to mirror background colour from my tv using this light plane
@dogxcd Hey there! Great question about syncing your TV’s background colors with the Aqara LED Bulb T1 (Tunable White).
Based on the available info, the Aqara LED Bulb T1 (Tunable White) supports adjusting brightness and color temperature (2700K-6500K range), along with scene modes like relax, movie, night light, etc. However, there’s no mention of RGB color capability or TV screen mirroring/ambilight-style synchronization in the reference materials.
For true TV background color mirroring (like Philips Ambilight or similar), you’d typically need RGB-enabled lights that can reproduce millions of colors and integrate with screen-capture software. The T1 is a tunable white bulb, not RGB — so it can shift between warm and cool whites, but can’t match the full spectrum of colors your TV displays.
If you’re set on that immersive TV backlighting effect, you might want to check out RGB-capable options like the Aqara Ceiling Light T1M, which features a 16-million-color RGBIC ring with dynamic gradient effects. That said, even with RGB hardware, you’d still need to confirm whether Aqara’s ecosystem or third-party integrations (like HomeKit, Matter, or IFTTT) support real-time screen content syncing — which isn’t detailed in the current references.
Want to explore what automations are possible with the T1? It supports triggers like “turns on/off” and actions like adjusting brightness, color temperature, and scene modes in the Aqara Home app.
