Aqara LED Strip Connector
Dears,
Could you recommend a connector or extension cable with fittings that attach directly to the connectors already fitted at both ends of the Aqara strip?
Hello.do you want to add more M to your LED strip?because if that is what you asking Aqara already sell an 1M extension LED strip
If you want to extend the strip, then you can probably use a standard 5pin RGBW connector (for 12mm/0.5in LED strip)
