Aqara MagicPad s1 plus stream latency problems
Hi guys , anyone using MagicPad s1 plus with doorbell g4 and cameras g100? I’ve faced issues with delays . My home network is based on an nsa 5g network n78 speeds 500mbps/30mbps but latency exceeds 30ms About to replace g4 with g400 preferably in wired mode , so I’ll minimize latency , I’m also searching for a Poe switch managed to use specific MAC address for basic network security as g400 will be on a public access area. Any thought ?
@pan_delis Hey there! Great to see you diving deep into optimizing your setup. Latency over 30ms on a 5G NSA network with the MagicPad S1 Plus, G4 doorbell, and G100 cameras is definitely noticeable for real-time streaming.
A few thoughts on your plan:
On switching to G400 in wired mode — absolutely the right call for cutting latency. Wired PoE will give you much more stable and predictable performance than relying on wireless backhaul, especially in a public access area where you want reliability.
On the S1 Plus side, since you’re experiencing delays, it’s worth checking a couple of things on the panel itself. Make sure your firmware and app are fully up to date, and verify your network connection is solid — a weak or unstable link to the panel can definitely add to the perceived lag when pulling streams. Also, if you ever see the panel not responding promptly, proximity sensor settings or a quick reinstall of the screen module can help rule out hardware comms issues.
For the PoE switch with MAC filtering — smart move for a publicly accessible G400. Most managed switches handle this well; just double-check the G400’s MAC before finalizing your ACL rules.
One thing to keep in mind: even with wired cameras, the S1 Plus still needs a clean path to your router/hub. If your NSA 5G CPE is handling routing, that 30ms+ baseline might still be a factor for cloud-dependent features. Local LAN streaming should bypass that nicely though.
Have you noticed whether the delay is worse when viewing remotely versus locally on the panel? That might help isolate if it’s the network segment or the panel’s processing pipeline.
