Aqara MFKZQ01LM Cube - Has anyone still got one of these?
Has anyone still got one of the legacy Aqara MFKZQ01LM Cube? I don’t mean the T1, I mean the older one. Due to the limited connectivity I struggle to find use for it.
It’s currently sat on my desk as it always is but the days of me using it to trigger cool stuff stopped some time ago.
I don’t want to get rid of the little fella but I always had to get it connected to do stuff using IFTTT then hooking it into Node Red. Then every now and again IFTTT would require re-authentication dropping the cube and my automations would break.
In the end I just re-wrote the automatons with alternative triggers.
I’d love to hear from others. Do you still have one? Does it still work in your setup? Have you found a better way to connect it?
@sbbit_sb I totally get the attachment to the little guy—the original Cube has that classic charm, even if the connectivity story was always a bit of a puzzle. Your IFTTT → Node-RED pipeline sounds familiar; that re-auth dance was a pain point for a lot of folks back in the day.
The original Cube’s triggers were pretty streamlined compared to what came later: Flip 90°, Flip 180°, Shake, Rotate, Double tap, Light push, and that “triggered after one-minute idle” condition. No side-specific recognition or scene modes like the T1 and T1 Pro eventually got.
For keeping it alive without the IFTTT headache, a few paths community folks have explored:
  • Direct Zigbee integration – If you’ve got a Zigbee coordinator (like Zigbee2MQTT or ZHA in Home Assistant), the original Cube can pair directly bypassing Aqara’s cloud entirely. No more auth tokens expiring on you.
  • Aqara hub + local automations – An Aqara Zigbee hub keeps things local; automations run even if your internet drops. The original Cube’s automations are all local to the hub once configured.
  • Aqara Studio / API route – For more advanced integrations, Aqara does provide API docs for third-party projects, though that’s more DIY.
The T1 and T1 Pro definitely expanded the playbook with action/scene modes and HomeKit support[“content_id”:3"], but there’s something satisfying about making the OG hardware work on your terms.
What alternative triggers ended up replacing it in your setup? Always curious how people reroute their automation muscle memory.
I had the old cube but not so accurate as I wish so not using it a lot.
Taking a couple ideas from here hehehe thnx!!
