I’ve been using the Aqara motion sensor for a while now, and it seems a bit too sensitive – triggering even when there’s minimal movement. Is there a way to reduce its sensitivity, either through the Aqara app or a third-party platform like Home Assistant?
Yes there is a Sensitivity setting in the Aqara app, you need to select the Device within the Accessories area, then the three dots in the top right. and then select “Device Settings” you will then see the options for Sensitivity and a dropdown for Low, Medium, High.
There is also an option for the Detection interval which lets you set how long to wait before another trigger is registered.
