Aqara NAS Storage not connecting
Hi,
I have an issue getting my Aqara cameras to save footage to my NAS.
I have 3 Aqara cameras, all different models.
For most of this year, all 3 were backing up via my NAS (to external hard-drives that are plugged into the NAS USB ports).
In August of this year, 2 of them stopped backing up to the NAS, and one continued to back up. No settings were changed on the NAS or Aqara products.
Today, I have tried to reconnect the two that were not backing up but have had no luck.
One of them has an error that I can’t fully see:
Note: the NAS and camera are both fully working and are connected to the same network.
For this camera, I can ‘Modify storage path’ but it still has the same error and does not back up any footage.
The other camera has a different issue. I tried to start again, and selected ‘Remove the NAS storage device’. I then tried to select the drive to save to, but I get this error:
I have tried wiping the hard-drive, and formatting the cameras’ SD card.
Can anyone help me get these working again? The cameras are still saving footage to the SD cards, but not backing up to the NAS.
Thank you.
Since one camera still writes to the NAS while the other two continue recording to SD, could you list the three camera models and firmware versions, plus the NAS model/software version? Please also type out the full error messages if you can retrieve them, with any account names or network addresses removed. Comparing a failed backup timestamp with the NAS authentication/file-service log could help distinguish a connection or permission failure from a storage-path problem; I would preserve the remaining footage rather than format anything else while narrowing it down.
