I’ve been using a modified Aqara temperature sensor, modified with an external SHT30 temperature probe - as an “Outdoor” sensor, by closing the temperature probe in the window. I followed this guide on Reddit: https://www.reddit.com/r/smarthome/comments/o3iwhk/aqara_sensor_with_external_temperature_probe_sht30/ and it’s been working great for a couple of years now.
Whilst it works well and is just as reliable as the unmodified version, it’s a bit of an eyesore and I’d love to see something more in line with the other products… but with an IP rating suitable for outdoor use.
Anyone else got a better solution, until Aqara release something, without needing to trap a cable through a window!?
@michael92 That’s a pretty clever DIY hack you’ve got running there! Respect for the ingenuity—modding an SHT30 probe into an Aqara sensor and keeping it reliable for years is no small feat. Totally get the “eyesore” factor though, and the window-cable situation is definitely not ideal.
From what I can see in the current lineup, Aqara’s sensors like the Climate Sensor W100 and the standard Temperature and Humidity Sensor are explicitly rated for indoor use only and aren’t waterproof. The W100 even notes to keep it away from direct sunlight and heat sources, so it’s really not designed for outdoor exposure. Unfortunately, I don’t have any info on an outdoor-rated Aqara temp sensor in the pipeline.
Your best bet for a cleaner setup without the window-gap cable might be:
Aqara Temperature and Humidity Sensor in a sheltered spot – maybe under eaves or in a weatherproof enclosure? It’s still not IP-rated, but protection from direct rain could stretch its life. Operating range is -20°C to +50°C with 0-100% RH, so it can handle the temp/humidity range at least.
Third-party outdoor zigbee sensors paired via an Aqara hub – brands like Sonoff or Tuya make IP-rated options, though integration can be hit or miss.
If you want to push for an official outdoor sensor, I’d definitely recommend feeding that suggestion through the right channels. You can reach out to the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, please click here to create a ticket.
Anyone else in the community found a slicker outdoor temp monitoring setup?
Well, nice hack! I already use an old Aqara temperature sensor outside for years without any covering- it’s just placed under the roof without getting wet by rain- just battery drains little faster
It will be great to see a smart exterior sensor that will detect temperature, humidity and more, like rain, hard winds etc
