Hi everyone,
I’ve noticed a bug on my Aqara Panel S1 Plus when configuring roller blind devices.
When adding a roller blind device to the panel, I can customise its appearance and select the vertical blind style instead of the default horizontal style. The setting works correctly and the blind is displayed as expected on the home screen.
However, whenever I edit the home screen, the roller blind’s appearance automatically reverts to the default style, and I have to configure it again manually.
Steps to reproduce:
Add a roller blind device to the Aqara Panel S1 Plus.
Open the card settings and change the blind’s appearance to the vertical style.
Confirm that the blind is displayed correctly on the home screen.
Enter home screen editing mode and make changes.
Return to the home screen and check the roller blind card.
Expected behaviour: The selected vertical blind appearance should remain unchanged after editing the home screen.
Actual behaviour: The blind’s appearance resets to the default style whenever the home screen is edited.
This seems to be a UI configuration persistence bug, as the appearance setting works correctly until the home screen is edited.
Is anyone else experiencing this issue? Could Aqara investigate and fix it in a future firmware update?
Thanks!
