I’ve been using the Aqara Presence Multi-Sensor FP300 for a few months now, and I’m really impressed with its capabilities. This device combines motion, presence, temperature, humidity, and ambient light sensors, making it a versatile addition to any smart home setup. Here’s my experience and some tips for integrating it smoothly:
Key Features I Love
- Motion and Presence Detection: The FP300 excels at detecting both motion and presence, which is perfect for automating lights or adjusting thermostats based on occupancy.
- Battery Life: Running on two CR2450 batteries, it promises up to 3 years of life on Zigbee, which is a huge plus for wireless setups.
- Multiple Mounting Options: The included adhesive pad, magnetic plate, and screws make it easy to mount almost anywhere without drilling.
- Customizable Settings: Through the Aqara app, you can tweak sensitivity, detection ranges, and even set absence delays to prevent false triggers.
Integration Tips
- Choose Zigbee for Reliability: While the FP300 supports Matter over Thread, I found Zigbee to be more reliable for consistent performance.
- Pairing Process: Ensure the device is in pairing mode and follow the Aqara app’s guided setup. If you’re switching protocols, be patient as it may take a moment to download the necessary firmware.
- Automation Ideas: Pair it with other sensors for advanced routines. For example, combine it with a light sensor to only trigger motion when it’s dark.
Challenges and Workarounds
- No Separate Motion Sensor: In Apple Home, the motion and presence sensors are treated as a single entity. If you need separate controls, stick with the Aqara app for more granular settings.
- Firmware Updates: Keep an eye on firmware updates, as they can enhance functionality and fix minor bugs.
The FP300 is a fantastic multi-sensor that’s both powerful and easy to integrate. Whether you’re using it for lighting automation, climate control, or just monitoring environmental conditions, it delivers on its promises. Plus, the ability to customize settings through the Aqara app makes it a standout choice for both beginners and advanced users.
If you’re looking to upgrade your smart home with a versatile sensor, I highly recommend giving the FP300 a try! ![]()
