Aqara Presence Multi-Sensor FP300
So I’ve had this for a few months now, been messing around with it in home assistant via zigbee protocol.
I had waited for a presence sensor that was battery powered and discreet in size for so long because of where I wanted it.
I have it in a utility room which also has a small pantry behind a door. Normally I would have to switch the light on for either room but then I’d forget the pantry light was on and sometimes it would be on until the next day!
So using home assistant I linked a Sonoff ZBMINIR2 relay to connect the two rooms lights, then using an automation, it would turn on when presence is detected by the Aqara sensor, then turn off if no activity in 1 minute.
It has been super useful especially when cooking and hands are a bit messy!
Agree - I’ve installed in every bathroom to control lighting and also extractor fan and working well - they are good! No issue with battery life either
