Aqara Radiator Thermostat E1 with Zigbee2MQTT alongside a Remeha eTwist: how to avoid conflicts?
Hi all,
I’m planning to make some of my radiators smart and would like your experience before I buy.
My setup:
  • Home Assistant Green with Zigbee2MQTT (Sonoff Zigbee dongle)
    Remeha boiler with a Remeha eTwist thermostat, which controls the whole ground floor
  • 13 radiators across 6 rooms
  • Plan: start with 5 radiators using the Aqara Radiator Thermostat E1, and keep standard knobs in the living room and kitchen where the eTwist is located
    I want local control, without cloud or API limits
My questions:
  • Conflicts with the eTwist: how do you prevent the TRVs and the central thermostat from working against each other (e.g. the eTwist calls for heat while the TRVs in other rooms are closed)?
  • Control strategy: do you set a fixed target temperature on each TRV, or schedule them from Home Assistant?
    Reliability of the E1 in Zigbee2MQTT: how are calibration, valve position, window-open detection and battery life in practice?
  • Alternatives: is there a better Zigbee2MQTT-compatible TRV I should consider before buying?
Thanks in advance!
@Expert Could you check this please?
I have nearly the same setup in the UK: one central thermostat (a Google Nest) and Aqara valves on almost every radiator, and the conflict you describe is real. My Nest sits near radiators on the landing, so the landing gets to about 23°C and stops calling for heat while my main bedroom is still under 20°C. The valves can only close, they can’t make the boiler fire, so my workaround has been setting the bedrooms higher than I actually want. I’ve now moved the call for heat into Home Assistant, using the room readings, with each valve holding its own room’s target. Your idea of keeping plain knobs in the eTwist room makes sense, just don’t rely on the eTwist alone to heat the other five rooms.
Thanks, that’s really helpful. I’m in the same situation with a single central thermostat. Did you control the boiler locally from HA, or through a cloud integration? And do you use one temperature sensor per room, or the valve’s own reading?
