Aqara SD-S01D Smoke Detector — Install + Away Alarm Linkage Not Working
Installed the SD-S01D in an open-plan kitchen/dining/living space, ceiling-mounted in the dining area on the kitchen side of a pendant light cluster — ≥0.5m from walls, clear of the kitchen’s cooking-smoke zone (Aqara advises against kitchen placement due to false alarms).
Now trying to link it to my Away alarm: IF a door/motion sensor triggers while armed, THEN sound the smoke detector’s siren — set up via Automation > IF/THEN in the Aqara Home app (hub). The rule saves but the siren doesn’t fire on test.
Has anyone gotten this linkage actually working? Does the siren show up as a THEN action for you, or only as a trigger? Wondering if it’s a firmware/region limitation or a setup step I’m missing.
Do they have smoke/CO2 detector for the USA
The smoke detector has been released in Europe but not yet in the US. And I’m not aware of one for the carbon monoxide.
Hello and welcome to the forum.well my guess is that the smoke alarms can’t be used as you have set them.being smoke detectors only can be used as that and not as home alarm when an door is open for that you need any hub with siren build in.i have 2 on my apartment and they are added automatically on the basic alarm same as the water sensors with only will trigger the siren when smoke is detected.but I also my be I am wrong still I never heard someone adding smoke detectors to trigger the siren when an door or window is open.
Thanks. I understand, it makes sense not to mess up with such a vital alarm. I’m looking for a louder alarm though (I have the embedded G3 hug alarm only), to reach the 80-100 db so it can be heard outside. Any idea besides the add of one of the other hubs?
Well I am using 3 hubs for that matter the M3 witch is the best of all hubs witch have multiple protocols, the M1S gateway and also have G3 camera witch I only use it as camera when all 3 trigger the alarm is loud at least for my apartment but I have them placed around the house so the alarm sound better.ether way you receive an notification too on your phone and watch.but this smart devices doesn’t and will never sound as loud as an real alarm system
