1. Unboxing and What’s in the Box
The Aqara Smart Lock U600 comes with everything needed for installation. Inside the box, you’ll find:
- Installation guide
- Front and rear lock assemblies
- Mounting plate
- 2 × keys
- 4 × AA batteries
- Double-ended screwdriver
- Panel positioning guide
- 2 × square spindles
- 4 × connecting sleeves
- Connecting screws (A, B and C)
- Silicone plug
The contents are well laid out, and having the installation accessories included makes it easier to get started.
2. First Impressions and Design
I was lucky to be one of the few early testers. My first impression of the U600 was very positive. The build quality feels good, and the lock looks well designed. It has a clean, modern appearance that should suit a contemporary home.
The U600 has a slimmer form factor, which I appreciate from an aesthetic perspective. However, personally, I would have preferred it to be slightly wider. That said, this comes down to personal preference rather than a fault with the product.
One thing worth mentioning is that the lock uses four AA batteries rather than an internal rechargeable battery. This is something to consider when thinking about ongoing battery replacement and maintenance.
3. Installation and Setup
Installation was surprisingly straightforward. As long as you follow the installation guide carefully, the process is simple and easy to follow.
Setting up the lock through the Aqara app was equally straightforward. I found the process a breeze, with no major difficulties during setup.
I did manage to snap one of the threads on a connecting screw during installation, but that was entirely my own fault. It is a reminder to take your time during installation and avoid overtightening the screws.
Overall, the installation experience was very positive.
4. Overall Verdict So Far
Based on my experience with the unboxing, design and installation, the Aqara Smart Lock U600 has made a very good first impression.
The build quality feels good, the design is modern, installation is simple when the instructions are followed, and setting up the lock through the Aqara app was effortless.
My main design preference would be for a slightly wider form factor, but that is a personal opinion. Apart from that, the U600 ticks all the boxes I would expect from a smart lock.
Would I recommend it based on my experience so far? My initial experience is encouraging. Further testing of its everyday operation and smart features would help me make a more complete assessment.
