Hello everyone
Why isn’t possible to disarm home alarm ( or chsnge status, home,night etc.)
while unlocking door using fingerprint on my U200 ?
Not quite sure what you mean, but you can just make an automation that
the alarm as long as you use Aqara as the alarm system.
You can do this but it’s not what i need.
Using fingerprint is more safe and mean the alarm is disarmed by a trusted person.
IF thief use a bump key or simply your stolen key is able to open the door and then the alarm goes down
Then add a geofence where any of your family phones are within the area to the automation, or get an outdoor camera/doorbell so you need facial recognition, plenty options available.
Thanks for help🙏
So you want to disarm the alarm whenever the door is unlocked but only if it’s unlocked via fingerprint?
Yesss
Fingerprint is a trusted trigger for disarming alarm
Unfortunately there’s no way to get that signal as far as I know. You could work around this by disabling all other unlock mechanisms but I understand that’s not ideal either
I have also asked this question on the Facebook page: why can we not have fingerprints as triggers? By that, I mean fingerprint X, Y, or Z could be used to create different automations, such as a “welcome home” automation for person X. It is really annoying that this information is stored in the logs, so why not expose these as triggers? Also, when you unlock your door, the alarm system should surely unset itself. I love aqara but some stuff is frustrating
I tried before, but I found the geofencing refresh rate to be quite slow; I cannot remember exactly what it is, but if you set your zone at 200m, for example, in a car you cover this distance in seconds, so it might be better if using the iPhone.
