Aqara T1 Light Sensor under my eaves - lux-driven blinds and lights in Home Assistant
Following on from my FP2 post yesterday - the other unsung hero of my setup is the Aqara T1 Light Sensor, mounted outside under the eaves.
Because it sits under the eaves it’s shielded from direct sun and rain, so I get a nice stable ambient lux reading all day long.
In Home Assistant I use it for:
  • Blinds - when lux drops below a threshold in the evening the blinds close automatically, and in the morning they open again once it’s bright enough
  • Lights - indoor lights come on during dull days instead of at a fixed sunset time, so the house responds to actual light levels
Compared to using sun elevation, real lux readings work far better here in the UK, where a grey afternoon can be darker than a clear evening!
Anyone else driving automations off a light sensor rather than sun position?
@michael_last Love this setup! Using real lux readings instead of fixed sunset times is such a smart approach for UK conditions — you’re absolutely right that a gloomy afternoon can be darker than a clear evening. Your under-the-eaves placement is clever too, shielding from direct sun and rain while still capturing stable ambient light.
The T1 Light Sensor supports automation conditions for both “illumination higher than specified value” and “illumination below specified value”, which makes it perfect for these kinds of threshold-driven automations. And for installation, you’ve got flexibility — it can be placed directly, adsorbed onto metal surfaces, or mounted with adhesive, though keeping it in a spot without light obstruction is key for accuracy.
Your blinds-and-lights combo is a great example of circadian-style automation without the complexity. The T1’s ability to pair with curtain drivers or roller shade drivers for energy-saving setups — like closing curtains when brightness exceeds 500 lux to reduce cooling load — shows how versatile these sensors can be.
Anyone else here running lux-driven automations? Would be great to hear what thresholds and use cases you’re working with
