Hi,
I can’t get my Aqara T1M ceiling light to pair with a Hub M3.
The lamp is constantly blinking blue and is not discovered by the hub.
What I tried:
- Multiple factory resets via 5× power on/off (but theres no change in the blue blinking)
- Pairing via Aqara Home app (EU region, manual add via Hub M3)
- Lamp placed close to the hub
- Other Aqara devices pair and work fine
The light always returns to blue blinking and never pairs.
Is it possible the T1M is still bound to another Aqara hub/account (I bought it on amazon the package has been opened already), or does this indicate a defective unit?
Is there any reset/unbind method beyond the power-cycle reset?
Thanks for any help.
Hi! The T1M should after reseting set back to factory settings - there’s no binding to another account then…
How far away is the lamp to the hub? To which server ( location) is M3 bound?
Is the T1M light breathing after the reset?
What do you mean by that?
The T1M dies not make any effect other than flashing blue despite what I read online that it should be white after reset. Thats why I assume it’s stuck in pairing.
and I have tried multiple distanced between the hub and the lamp its unlikely its the cause.
Hello, welcome to the forum. Are you sure you have a fixture for the European region? There have been cases of devices being sold that are intended for the Chinese region. Such a device will not connect to a gateway in Europe.
Exactly! That’s why I supposed that it’s maybe the wrong server
okay so I should return to amazon.de and buy a new one?
Maybe show a video of it… So we can see more!
If it doesn’t help, then I would return
Hey did you manage to resolve this? I have the same issue - blinking blue light on the outer leds.
I’ve tried to initiate a reset using the wall light switch and toggling it on and off 5 times, 3 times,
10 times - not change.
I see on some forums there might be a physical button on the unit that I can hold for 5 seconds to reset but can’t find this - so stuck with flashing blue outer ring of lights
Hello, tell me how it started? After some time of work or during installation. Maybe you deleted the lamp from the application. What gateway are you using?..
Tried to add it to a new base G410 hub,
