Aqara Temperature & Humidity Sensor – How Accurate Is It?
For those who own the Aqara temperature and humidity sensor: how accurate have you found the readings to be compared to other thermometers/hygrometers? Is there a way to calibrate it if it’s off by a degree or two?
Quite accurate compared to Bosch sensor.
There’s no option to calibrate in Aqara app
They are pretty accurate. Philips hue which I also use is off by 2 degrees.
