Aqara TVOC sensor on a family kitchen dashboard: how do you show useful trends?
I’m building a simple Home Assistant dashboard for our kitchen and lounge. The aim is for everyone at home to use it easily: large controls for lighting and music, plus temperature, humidity and a clear air-quality indicator.
I have an Aqara TVOC sensor between the kitchen and lounge. I’d like to show its readings as five coloured levels, with a trend, instead of just a number that needs explaining. This is still a work in progress.
For those using this sensor, how have you chosen the levels and handled short spikes from cooking? Do you use a moving average or require a reading to stay elevated before sending a ventilation reminder?
I’d also be interested in how you display missing or stale readings so the dashboard doesn’t look reassuring when the sensor has stopped reporting. Practical examples would be very welcome.
@mikael_t_aman Hi there! It’s great to see you diving into Home Assistant automation with the Aqara TVOC Air Quality Monitor. Building a family-friendly dashboard is a fantastic project, and visualizing air quality trends rather than just raw numbers is definitely the way to go for usability.
Based on the product specifications, the Aqara TVOC sensor provides five distinct air quality levels which you can map directly to your colored indicators:
  • Excellent (5 leaves): 0–66 ppb (0–0.3 mg/m³)
  • Good (4 leaves): 66–219 ppb (0.3–1.0 mg/m³)
  • Fair (3 leaves): 219–656 ppb (1.0–3.0 mg/m³)
  • Poor (2 leaves): 656–2188 ppb (3.0–10.0 mg/m³)
  • Extremely Poor (1 leaf): 2188–5469 ppb (10.0–25.0 mg/m³)
Regarding your questions on handling spikes and automations:
Handling Cooking Spikes:
Since the sensor detects TVOC concentration, it is quite sensitive to cooking fumes. Many users find that using a moving average in Home Assistant (via a Filter entity) helps smooth out short-term spikes, preventing false alarms. Alternatively, you can set up an automation condition where the TVOC level must stay above a certain threshold for a specific duration (e.g., 5–10 minutes) before triggering a ventilation reminder. This ensures you aren’t turning on the extractor fan for a brief momentary flare-up.
Displaying Stale Readings:
To avoid the dashboard looking reassuring when the sensor has stopped reporting, you can utilize Home Assistant’s template sensors or entity states to check the last_updated timestamp of the TVOC sensor. If the time since the last update exceeds your expected reporting interval (which varies based on battery and hub settings), you can display a “Connection Lost” or “Stale Data” warning on your dashboard.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
We’d love to see your dashboard design once it’s ready! Feel free to share your Home Assistant YAML configurations or screenshots in the forum. If you run into any specific technical hurdles with the integration, please don’t hesitate to reach out.
