my u100 smart lock is malfunctioning, for the past few days each time i would close my door and press the lock button the lock would lock, but then the error sound would go off and i would get a notification that the cylinder did not extend fully, but yet the door is locked. so last night i decided i would try to run the calibration lock setting and it failed during the test, and now when i manually lock the door, a few seconds after the lock would unlock it self.
anyone have issues with the calibration failing?
what did you do?
thanks,
Looks like support has got a case to assist you. If you manually lock the door, does the knob turn all the way? Could the door have settled causing a little resistance to the motor? If not, maybe a product malfunction.
Aqara’s U100 FAQ has a check for this: pull the batteries and turn the inside knob by hand. It should lock and unlock with zero effort. If it drags, take off the back panel and make sure the cable isn’t rubbing the tailpiece and the tailpiece is centered in the deadbolt hole.
If it’s only tight with the door shut, the strike hole in the frame is off. Once it turns freely, rerun calibration (Settings > User Guide in the app). Don’t factory reset it, since that wipes all your users. The unlocking-itself part isn’t covered anywhere, so keep the support ticket going.
