I’ve had my Aqara U200 smart lock for about six months now, and I must say, it’s been a mostly smooth experience. However, after the fourth month, I started noticing some strange noises and occasional jams. At first, I thought it might just be a minor glitch, but when the calibration stopped working, I knew I had to take action.
After some research, I discovered that this issue isn’t unique to my lock—it seems others have encountered the same problem. The culprit? A less-than-ideal lubricant used during manufacturing. I decided to take matters into my own hands and give my lock a little TLC.
Here’s what I did: I carefully disassembled the lock, making sure to follow all safety precautions. The process wasn’t too bad once I got the hang of it. I cleaned out the old, dried-up grease and applied a fresh coat of high-quality lubricant to all the gears. The difference was immediate—my lock now operates smoothly, and the noises are completely gone!
I want to share this process with others who might be facing the same issue. While voiding the warranty wasn’t ideal, it was worth it to save on the cost of a new lock. If you’re handy and patient, this fix could be just what your Aqara U200 needs.
Pro Tip: Always double-check your warranty before attempting any DIY repairs. If you’re unsure, reach out to the manufacturer or a professional for assistance. Happy tinkering! ![]()
