Aqara U400 Detection Distance
I would like to start off saying that I absolutely love this lock. It was stupidly simple to install and set up and it locks and unlocks very fast. The only thing that I don’t like about it is that it seems to detect my iPhone at different distances and sometimes not at all.
Most of the time, it detects my iPhone after I have walked all the way to the door and have to stand for a couple of seconds. Maybe 20% of the time, it will detect my iPhone when I am about 3ft away and unlocks which is perfect! And then finally, maybe 5% of the time, I will walk up and it doesn’t do anything and then I have to use my fingerprint.
What is everyone else’s experience with this?
I would say my experience is about exactly what your experience is. 90% of the time it doesn’t bother me. And honestly the 10% is probably okay just wished it was 100%. Does yours work from inside as well? Mine doesn’t.
Does it unlock from the inside you mean? It’s not supposed to. It would be convenient if it did but at the same time, if someone with ill intent came up to your door, it would automatically unlock for them to come right inside and you’d be face to face with them.
I love that my Apple Watch unlocks my door! That means I don’t need to take my iPhone on my runs.
lol I guess when you put it that way that actually makes a ton of sense.
Mine has been fairly consistent. When I walk straight toward the door, it usually unlocks before I need to touch the keypad. If I spend some time outside getting things from the stroller or moving around near the entrance, I sometimes have to get much closer to the lock before it unlocks. It still opens, but the detection distance seems less predictable in that situation. Overall, the UWB unlocking has been reliable for me.
I dug into the features to find how to change this (as this was one complaint I had about my August Smart Lock - which we replace with the u400: :slight_smile:
Open Aqara App
  • Click on your lock
  • Click on the 3 dots in the upper right corner to go into Settings
  • Scroll down and go into UWB Settings
  • Click on UWB Laboratory
  • Click on Unlock Distance (default value is 1 meter)
You’ll get a warning dialog that increasing the distance may cause accidental unlocking
  • Click Got It
You can now scroll up or down to increase or reduce the distance - click Confirm once you’re happy with your choice.
Then you can trial it out - see how well it works for you. :slight_smile:
