Hi everyone,
I’ve connected my Aqara V1 track lights to an Aqara Hub M3 via Zigbee, but the lights are not showing up in Home Assistant through the M3’s Matter bridge.
The setup I’m trying to use is:
Aqara V1 track lights → Zigbee → Aqara Hub M3 → Matter → Home Assistant.
Does the M3 currently support exposing V1 track lights to Home Assistant over Matter? If so, are there any specific settings or steps needed to make them appear? Could this depend on the hub/light firmware or the Aqara Home region?
Has anyone managed to get this exact setup working? I’d appreciate any troubleshooting tips or step-by-step instructions. If Matter bridging isn’t supported for these lights, is there another way to add them to Home Assistant while keeping them connected to the M3?
Thanks for your help!
Joining the V1 lights to the M3 over Zigbee does not by itself prove that the M3 exposes that device type through its Matter bridge. I would first check the M3’s Matter bridge device list in Aqara Home: if the V1 lights are absent there, Home Assistant cannot discover them from that bridge, so confirm Aqara’s supported bridged-device list and current hub firmware before resetting anything. If they are listed there but missing in Home Assistant, then focus on the Matter Server/controller path. The fallback is a separate Zigbee coordinator, but that would mean moving the lights off the M3.
Hi there! I am also trying to find out if this is workable. Are you currently able to integrate your v1 tracklights into home assistant? The only workaround that I find out is that I can use v1 tracklight on/off scene and expose it to home assistant, but we won’t get direct control of the lighting. So let me know if you managed to solve it
