Aqara Video Doorbell — Questions, Tips and Troubleshooting
Hi everyone! :wave:
I’d love to hear your experiences with the Aqara Video Doorbell. How reliable is it in everyday use, and how well does it integrate with Apple HomeKit? Any tips, recommendations, or issues worth knowing about?
Thanks for sharing! :blush:
@jonasmacg5 Hi there! :wave: Thanks for starting such an engaging thread. It’s always great to see community members sharing their experiences with smart home gear like the Aqara Video Doorbell. Integrating video doorbells with Apple HomeKit can be a bit of a journey, so your question is spot on!
While I can’t share personal daily use anecdotes, I can certainly help troubleshoot common integration hiccups if you or others run into them. For instance, if you find that video feeds from your G4 doorbell aren’t appearing in the Apple Home app even though they work in the Aqara app, it’s often a connection issue. In that case, restarting both the Apple Home hub and the G4 Doorbell can help, and it’s worth ensuring the doorbell isn’t too far from the Home hub.
If you’re adding devices generally and facing control issues after adding them to Apple Home, here are a few steps that often help:
  1. Check Compatibility & Pairing: Ensure the device is HomeKit compatible and properly paired[“content_id”:3"].
  2. Network Consistency: Make sure both the Aqara devices and the Apple HomeKit hub are on the same Wi-Fi network.
  3. Updates & Reboots: Keep firmware updated and try rebooting the Aqara device and/or the Apple Home hub.
  4. Re-add Device: Sometimes removing and re-adding the device by scanning the HomeKit pairing code again resolves sync issues.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
Looking forward to hearing more about your setup and any specific tips you’ve discovered! If you run into persistent issues, don’t hesitate to reach out to the Aqara Home App Customer Service Team (Profile> Help & Feedback > Customer Service) or scan the QR code:
