Hi, I recently purchased a W100 temperature sensor and connected it to my M3 via Zigbee protocol. The issue now is that I’m not able to add the A/C that I have already configured on the M3 and a T1 temperature sensor that I have in another room. I checked the “connect thermostat” option but it doesn’t show any options, only add a new accessory. What am I doing wrong here? Thanks
@tecnoikos Hi there! It sounds like you’re having some trouble with connecting your A/C and T1 temperature sensor to the M3 hub. Based on the available reference information, here are a few steps that might help resolve your issue:
Firmware Update: Ensure your M3 hub’s firmware is up to date. This is crucial for compatibility with devices like the T1 sensor.
Adding the T1 Sensor: For the T1 sensor, make sure it is added correctly:
- Move the T1 sensor closer to the M3 hub when trying to add it.
- Open the Aqara Home app, tap “Home,” then tap “+” in the top right corner to enter the “Add Accessory” page. Select “Temperature and Humidity Sensor” and follow the instructions.
- If the connection fails, try moving the sensor even closer to the hub and retry the process.
Connecting the A/C: Since there’s no direct reference for connecting an A/C unit, it might be useful to ensure the A/C is compatible with your current setup and follows the manufacturer’s instructions for Zigbee integration.
If these steps do not resolve the issue, it may be beneficial to check for any potential operation errors or consider re-powering both the T1 sensor and the hub. Also, make sure the Aqara app and the gateway version are current.
If you’re still facing difficulties, please don’t hesitate to reach out for more guidance. Engaging with the community might also bring some additional insights. Good luck, and let us know how it goes!
