TLDR; Does the W200 Thermostat have all the features I desire, for my standard 24V heating-only house in North America.
- Handle hydronic heating appropriately with a proper deadband for very slow reacting concrete slab.
- Allow for thermostat scheduling on the thermostat itself, with AT LEAST 4 blocks per day (Morning, Day, Evening, and Sleep) in ‘Home’ mode (or equivalent)
- Allow for Away (or Vacation) mode where the schedule is effectively disabled, but the temperature is set to a MUCH lower value that doesn’t change
- Allow for local (ie; no cloud) control that allows me to change the schedule and/or mode.
More details:
I currently am using Home Assistant, and my current thermostat is a Honeywell T6-Zwave, which allows for (3) and (4). However, it works VERY poorly for issue 1 due to it’s extremely tight window, causing my in-floor heating to cycle very quickly (12-18 times/day since it has a 1 degree window). Also, the onboard schedule on the T6 only has 2 choices, which I’ll call ‘awake’ and ‘asleep’. I’m working around (1) with some automations to bump up/down the actual setpoints, which is less than ideal, but work fine (if inefficient) even if my smarthome automation is not working.
The house is located 100 miles away from my primary residence (for now), but when completed will be my only residence (I’m currently in year 4 of 5). Because it’s not occupied for large portions of the year, I desire the ability to have the house go dormant (temperature set to 50F in the winter), but when I or other family members want to use the house, we need the ability to preheat the house to a comfortable level (~70), and once there, have the house run a set schedule to keep it comfortable. Preheating the house from 50 → 70 takes somewhere from 12-18 hours, so without preheating the first evening in the house would be VERY uncomfortable, so having the ability to remotely control the thermostat is a must-have.
Adaptive heating sounds great on paper, but the house is used by family who show up for the weekend, and enter/leave the house at-will. Because the house has a very slow heating/cooling cycle (concrete slab with pipes running in it), trying to optimize the temperature for wildly changing schedules and users is a losing proposition.
Another gotcha is because the house is in a remote location with few residence, power outages are extremely commonplace, so I can’t rely on my automation platform working, as the computer may not bootup properly, remote VPN access may fail, etc… Therefore, I need a thermostat where the ‘normal’ thermostat behavior is on the thermostat itself and has no reliance on an automation platform. I would hate for the house pipes to freeze simply because the internet didn’t come up, or my automation server refused to boot properly.
Because the W200 is using Matter, I would think that local control is a no-brainer, but the existing documentation is less than useful when it comes to onboard schedules, which controls are exposed outside the Aqara app, and how much flexibility is available to change the thermostat setpoint deadband and such. The manual hints at all of these features, but without enough details to answer my questions.
Thanks in advance for any insight you can provide.
