Aqara W600 hysteresys 600 is unusable at least for European customers
Hi there …. It is mentioned in some FAQ posts, that the w600 has
a built in fixed hysteresis of 2°. If so the W600 is unusable in at least most of European Country’s. It is a huge difference if you have only 18 c° in a room, even if you set the w600 to 20 c°. The offset setting in the app does not help at all if you are using an external temp sensor. The setting is ignored in this case.
