Aqara Water Leak Sensor: Catch the Drip Before It Becomes a Flood
Category: Aqara Products | Suggested tag: ProductSpotlight
Hey Aqara Community! :wave: A small leak under the sink can turn into an expensive repair. Let’s look at the Aqara Water Leak Sensor.
What is it?
A compact Zigbee sensor that detects water using the electrical conductivity of water. When its two probes touch water, it signals your Aqara hub.
Key features
  • Early detection: triggers when water reaches about 0.5 mm.
  • Alarm and notification: the hub sounds a local alarm and your phone gets a push alert.
  • IP67 rated: dust-tight and protected against short-term immersion.
  • Long battery life: a CR2032 coin cell, about two years in normal use.
  • Anti-UV shell to resist discoloration.
  • Automation-ready: pair it with a Smart Plug and a solenoid water valve to shut off the water automatically.
Good to know
  • It requires an Aqara hub.
  • Good spots: under sinks, behind toilets, near the washing machine, dishwasher or water heater, and in basements.
  • Place it flat on the floor where water would collect.
Idea to try
Leak detected → hub alarm sounds → Smart Plug cuts power to the water valve → you get a notification.
Join the conversation
Has one of these ever saved you from a disaster? Share your story below! :point_down:
he sensor triggers at around 0.5 mm of water, and your hub will sound the alarm and send a phone alert. Make sure it’s sitting flat where water would pool. Let us know how it goes! :droplet:
