Hi there,
amazon in my country still sells both “original” both “T1” version. What is difference between the two? I have an Aqara Hub M200. Is T1 taking any advice on zigbee range?
thanks!
Hey there.from what I know the T1 uses the 3.0 zigbee version and the normal one I think is 1.2 I have the normal and works perfectly fine all depends on your zigbee connectivity and how many zigbee bridges devices you have around the house like LED strip smart plugs or smart light bulbs or even smart switches with neutral line.for me all works great with excellent zigbee signal and I have them connected to my M3 hub witch is not near to them but I have the Aqara LED strip in between that makes an bridge between M3 and sensors
The T1 device is a Zigbee 3.0 Device and support OTA updates!!
Main Differences: T1 vs. Original Sensor
Zigbee Version: The original sensor uses older Zigbee 1.2 HA, whereas the [T1] model upgrades to Zigbee 3.0 for a more reliable, secure, and resilient mesh network capacity.
OTA (Over-The-Air) Updates: The T1 series supports firmware updates directly through an Aqara hub, improving long-term stability and adding new features over time—something the original model lacked. ]
Anti-UV Outer Shell: The T1 features an anti-UV material body designed to resist yellowing and discoloration when exposed to ambient light over years of use
My bad I knew was something with 3 ![]()
will correct my post
No worries!!! ![]()
So the original leak sensors can’t update their firmware? That doesn’t seem right.
Correct
Wow. When I look at the version number on mine (original), and click firmware update, it just says I’m up to date. Sorta shady.
Thanks for sharing the comparison. I returned both my water leak sensor and temperature and humidity sensor and replaced with the T1 version.
Where do you buy your Leak Sensor T1??? First, I can go to Amazon as shown here:
And I purchased this TWICE, thinking it was the T1 because it is the ONLY Aqara Leak sensor listed on Amazon.
So I go to the Aqara site for a search:
I then click on the Store button:
Then I click on the Water Leak Sensor button:
How am I supposed to know what I’m getting here?
@aqara
Hi @starlitter
You can identify the version by the model number
Aqara Water Leak Sensor T1 - WL-S02D
Aqara Water Leak Sensor - SJCGQ11LM
Sure, but that’s after I buy it. That’s how I know mine are not T1s. But the websites (as shown) leave everyone guessing.
Judging by the reviews, these are the first-revision sensors, and it doesn’t look like they will be the T1 version.
Right! But those are screenshots from today. Where can I buy a T1? The Aqara site pulls a bait and switch.
@AqaraOfficial
There is some slight confusion regarding the sensor model; please take note of this.
Thank you, @Raman.V
Could I get a link or something to a place I can buy the T1? I’m in the U.S. and just don’t want to buy more leak sensors that I think will be T1s but are not. Thanks.
