Aqara Water Leak Sensors – Placement Tips and Real-World Performance
I use Aqara leak sensors in the kitchen (dishwasher, stopcock, water softener) and bathrooms. They’ve been reliable so far, but I’d like to hear how others place theirs for maximum coverage and whether you’ve had any false positives or missed leaks.
@imranbaharil It’s wonderful to hear about your positive experience with the Aqara Water Leak Sensors in your kitchen and bathrooms! For optimal placement, you can consider the following tips:
  1. Direct Placement: Ensure that the sensors are placed directly on surfaces prone to leaks, such as under appliances or near plumbing connections. This method is straightforward and effective for detecting leaks quickly.
  2. Using Probes: If you want to enhance the coverage or adapt to unique setups, you can use a hex screwdriver to loosen the sensor probes and connect them to cables. This setup can help extend the sensor’s reach in more complex or inaccessible areas.
  3. Surface Considerations: Keep in mind that installing the sensor on a non-metallic surface will prevent signal interference, ensuring a reliable connection to the Aqara Hub.
Regarding false positives or missed leaks, the Aqara Water Leak Sensor is designed to be quite reliable, meeting IP67 dustproof and waterproof standards. However, regular maintenance, such as checking battery levels and ensuring a stable connection with the hub, can further enhance performance.
I’d love to hear more about your experiences and any specific challenges you’ve faced. Feel free to share your insights or ask additional questions!
@imranbaharil It’s great to hear your Aqara leak sensors have been reliable in the kitchen and bathrooms! For placement, the Aqara Water Leak Sensor supports two main methods: placing it directly on the surface where you need to monitor leaks, or using a hex screwdriver to loosen the probes and connect to cables for more smart scenes . As for false positives or missed leaks, the reference information doesn’t cover that, but we’d love to hear from other community members—feel free to share your experiences or tips to help each other out!
@imranbaharil Thanks for sharing your experience with the Aqara Water Leak Sensors! It’s great to hear they’ve been reliable for your kitchen and bathroom setups. For placement, the sensor supports two main methods: placing it directly on the surface where you need to monitor leaks, or using a hex screwdriver to loosen the probes and connect cables for more flexible coverage in smart scenes .
As for maximizing coverage and experiences with false positives or missed leaks, it’d be wonderful to hear from other community members—feel free to share your tips or real-world stories! This kind of shared insight helps everyone get the most out of their sensors.
I gut false positives every couple of days from one of the two water leaks. Have no idea why.
@skzzz You seem to be experiencing an issue with false positives from your water leak sensor. You can contact customer support for assistance. Contact the Aqara Home App Customer Service Team (Profile> Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, Please click here to create a ticket.
