AQARA Wireless Mini Switch T1 - Automation - Single press vs Single press to unlock the door
Hi!
I have purchased an Aqara Wireless Mini Switch T1, to be used as a more convenient way to unlock the door, where I have the Aqara Smart Lock U200 (Rev. 2025).
When I am setting up the automation in the Aqara App (via M3 Hub), I have chosen a simple setup where when the button is single pressed, it will open the front door.
But in the When section, I have noticed that the button has to possible actions. Single press and “Single press to unlock the door”.
What is the difference?
Thank you!
Hi, welcome to the forum. These functions work exactly the same way as a single press. You can use a double press to trigger a different automation (for example, turning the lights on or off).
By the way, you can turn your button into a keypad; I described the automation in this tutorial: Automation 2.0, lesson 24, code lock from Aqara wireless button
