Aqara wireless mini switch T1
Hello!
I use Aqara wireless mini switch T1 for Aqara G3 HUB. It happens several times that I press the switch and the HUB says that I have connected the switch. It works for the next switch. Why can it do this?
Aqara wireless mini switch T1 (0.0.0_0032 software)
Aqara G3 HUB (4.3.8_0008.0013 software)
Thank you for your help!
Regards
Generally speaking when you hear that the hub says connection successful it means a check has been made between the end device and the hub.
Is could be that your button has lost connection, perhaps the next time you don’t use your button for a period of time check in the Aqara app it’s current status.
Do you have any other Aqara mains powered devices connected to the M3 as the button could be connected to them and not the M3 directly.
Hello, another possible option is that after the first connection, this situation may occur within a day. Only the first day. I had this happen to me.
