Aqara Wireless Switch (Zigbee2MQTT) - Single, Double, and Hold Actions
Hello everyone,
I’m trying to set up my Aqara wireless switch (model WXKG11LM) with Zigbee2MQTT to work with single, double, and hold actions. I found a blueprint that seems to be tailored for this exact setup, but I’m running into some issues. The switch comes in different versions, and I need to make sure I have the one that supports all these actions. I’ve checked the documentation, but I’m still a bit confused about how to proceed.
My Setup
- Switch Model: WXKG11LM
- Integration: Zigbee2MQTT
- Home Assistant Version: 2023.10
What I’ve Tried
- Blueprint Installation: I downloaded the blueprint from gist.github.com and added it to my configurations. The switch is paired successfully, but the actions aren’t being triggered as expected.
- Testing Actions: I’ve tested single, double, and hold presses, but only the single press works reliably. The double and hold actions don’t trigger any responses.
- Configuration Check: I reviewed the configuration file, and everything seems correctly set up. The supported actions are listed as single, double, and hold, but they aren’t functioning properly.
Questions
- Version Compatibility: How can I confirm that my switch supports all three actions? The documentation mentions different versions, and I want to ensure I have the correct one.
- Blueprint Adjustments: Are there any modifications I can make to the blueprint to improve reliability? I’ve tried adjusting the delay settings, but it hasn’t helped.
- Troubleshooting Tips: Are there any specific steps I should take to diagnose why the double and hold actions aren’t working? I’ve checked the logs, but I don’t see any errors related to the switch.
Community Input
Has anyone else successfully set up their Aqara switch with all three actions? I’d love to hear about your experiences and any tips you might have. I’m also curious if there are alternative blueprints or configurations that work better.
Next Steps
If I can’t resolve this on my own, I might consider reaching out to the developer of the blueprint or the Zigbee2MQTT community for further assistance. Any guidance you can provide would be greatly appreciated!
Thank you in advance for your help!
Best regards,
