Aqara Z1 issue in HomeKit
did any one of your Z1 single rocker in Homekit grey out but it cant control as normal
@marcuschai87 It sounds like you’re experiencing an issue with your Aqara Z1 single rocker in HomeKit where it’s grayed out and not functioning as expected. This kind of issue can often be related to connectivity or configuration problems. Here are some troubleshooting steps you might find helpful:
  1. Check Device and Hub Status: Make sure both your Aqara device and hub are powered on and online. If the device is in sleep mode or powered off, it might not respond.
  2. Network and Connection: Ensure that your Aqara device, hub, and HomeKit hub (such as an iPhone or iPad) are all connected to the same stable Wi-Fi network. A weak or unstable signal can cause connectivity issues, so consider moving closer to the router or restarting your network devices.
  3. Restart Devices: Sometimes, simply restarting your Aqara device, Aqara hub, and HomeKit hub can resolve temporary connectivity issues.
  4. Firmware Updates: Check if there are any firmware updates available for your Aqara device and hub through the Aqara Home app. Keeping your devices updated can help fix known issues.
  5. Re-sync or Reset: If the issue persists, you might need to re-sync the device by removing and re-adding it to HomeKit via the Aqara Home app. As a last resort, you can reset the device to its factory settings, but keep in mind this will erase all configurations.
If these steps don’t resolve the issue, it might be beneficial to reach out to Aqara support for further assistance. Feel free to share your experience or any additional insights you have with the community, as it might help others facing similar issues.
@marcuschai87 It sounds like you’re encountering a connectivity or control issue with your Aqara Z1 single rocker in Apple HomeKit, where the device is greyed out and unresponsive. Here are some troubleshooting steps that might help, based on common HomeKit and Aqara device issues:
First, ensure the Z1 switch is properly synced to HomeKit. Child devices like the Z1 can’t be added directly via the HomeKit app—they need to be added to the Aqara Home app first, then synced through the hub when the hub is added to HomeKit .
If syncing is correct, try these steps to resolve control issues:
  1. Check compatibility: Confirm the Z1 switch is HomeKit-compatible (it should have the “Works with Apple HomeKit” label) .
  2. Verify network connection: Ensure both the Aqara hub and your Apple HomeKit hub (iPhone, iPad, HomePod) are on the same Wi-Fi network, as unstable or mismatched networks can cause disconnections .
  3. Update firmware: Check for updates for the Z1 switch (via the Aqara Home app) and your Apple devices, as outdated firmware can lead to functionality issues .
  4. Reboot devices: Restart the Z1 switch (power cycle it), your Aqara hub, and your Apple HomeKit hub. Sometimes a simple restart resolves temporary glitches .
  5. Re-add the device: If the issue persists, remove the Z1 switch from HomeKit, reset it, and re-add it by scanning the HomeKit code again .
Have you tried any of these steps already? It might also help to check if other Aqara devices connected to the same hub are working normally, to rule out a hub-specific issue. Feel free to share your experience—other community members might have additional tips!
If the problem continues, you can also consider reaching out to Aqara support for further assistance.
@marcuschai87 It sounds like you’re running into a frustrating issue with your Aqara Z1 single rocker in HomeKit. When devices grey out and become unresponsive, there are a few common troubleshooting steps that might help.
First, check if the Z1 Pro is properly paired with HomeKit—sometimes re-pairing can resolve connectivity glitches . Ensure both the device and your HomeKit hub (like an iPhone or HomePod) are on the same Wi-Fi network, as a weak or inconsistent connection can cause this issue . Updating the firmware for both the Z1 Pro and your HomeKit hub is also a good step, as outdated software can lead to compatibility problems . If the issue persists, try rebooting the device and the hub, or even removing and re-adding the accessory in the Home app .
Have others in the community experienced this with their Z1 rockers? Feel free to share your own fixes or workarounds—collaboration often helps uncover solutions!
@marcuschai87 If your Aqara Z1 single rocker is greyed out and unresponsive in HomeKit, here are some troubleshooting steps to try:
  1. Check Compatibility: Ensure the Z1 switch is compatible with HomeKit by verifying the “Works with Apple HomeKit” label on the product or Aqara’s official website .
  2. Verify Hub Connection: Confirm that your Aqara hub (connected to the Z1) is on the same Wi-Fi network as your HomeKit hub (e.g., Apple TV, HomePod). A network mismatch can cause communication issues .
  3. Update Firmware: Ensure both the Z1 switch and the Aqara hub have the latest firmware updates. Outdated firmware may lead to compatibility problems .
  4. Reboot Devices: Restart the Z1 switch, Aqara hub, and HomeKit hub. Power cycling can resolve temporary connectivity issues .
  5. Re-add to HomeKit: Try removing the Z1 switch from HomeKit and re-adding it by scanning the HomeKit pairing code. Incorrect setup can cause unresponsiveness .
If the issue persists, check if the Z1 functions normally in the Aqara app. If it works there but not in HomeKit, the problem is likely HomeKit-specific .
Hope these steps help! Feel free to share your progress or ask for more details—community insights can often shed light on tricky issues.
