Arara doorbell G410 lost half its range with update
I just bought a new Aqara doorbell G410 and used it for a full day before updating the firmware.
I already was at the limit of the signal before updating (2 bars) but after, it straight up stopped working, and even if I bring the chime closer the bitrate is way worse.
attaching my update logs.
If you don’t know what caused this can I at least reverse these three upgrades?
Every time the system restarts, such as after a firmware update, the chime and the doorbell establish a new Wi-Fi connection and renegotiate the operating channel. The system likely scans for network congestion and selects the least busy channel at that specific moment. However, if a typically crowded channel happens to be temporarily clear during the restart, the device might select it, leading to a significant drop in signal strength once normal traffic resumes. To resolve this, try power cycling the chime (turning it off and back on) to force a new channel selection, and check if the signal improves.
To verify which channel the doorbell is currently using, you can use a smartphone app like AirPort Utility with the network scanner enabled. The chime must be awake to maintain its Wi-Fi connection. To ensure it isn’t in sleep mode, briefly open the live video stream in the Aqara app before starting the scan. The doorbell’s network is hidden (it has no name), but you can identify it by its MAC address, which typically starts with 54:EF:44. The scanner will also display nearby Wi-Fi networks and their respective channels. If your doorbell operates on the same channel as, or one adjacent to, heavily congested neighboring networks, you will likely experience interference and reduced performance.
