I recently decided to put my Arduino Micro to good use by creating a custom security panel for my home. It was a fun project that combined my interest in coding with my desire to enhance my home’s security. Here’s what I did and where I could use some help!
The Setup
I already had some wiring in place from my old security system, so I repurposed that. The Arduino Micro became the brain of the operation. I created a plugin for Vera to integrate everything seamlessly. The plugin expects serial input terminated by a carriage return and line feed, which is pretty straightforward.
The plugin creates a parent device with child devices based on the number of zones, which I can set under the parent device. Each zone can be configured as a Door Sensor, Motion Sensor, Smoke Sensor, or Temperature Sensor. This flexibility is great, but I’m sure there’s room for improvement.
Features
- Door, Motion, and Smoke Sensors: These sensors have variables to match specific strings to trigger or un-trip them. It’s a simple yet effective way to customize their behavior.
- Temperature Sensors: These expect serial input with the circuit number and temperature reading, making it easy to monitor multiple areas.
Challenges and Questions
While the project worked out of the box, I’m looking for ways to make it more robust. For example, how can I handle unexpected inputs or errors gracefully? Also, I’m curious about best practices for organizing the code to make it easier to maintain or expand in the future.
Community Help
I borrowed some code examples from the community, which I’m really grateful for. If anyone has suggestions or improvements, I’m all ears! Whether it’s about code structure, error handling, or feature enhancements, your input would be invaluable.
Closing Thoughts
This project was a great learning experience, and I’m excited to see how it evolves with your help. If you’ve worked on similar projects or have tips for a first-time plugin developer, please share them below! Let’s make this security panel as solid as it can be together.
Thanks in advance for your insights and support!
