Are Aqara smart lock keypads waterproof?
Wanting to use it on the alleyway gate. If they’re not waterproof are there any covers that can be purchased or 3D printed maybe?
Yes, people have those outside with no problem. For example the U200 has IPX5 rating, 5 means that the device can withstand water jets spraying in its direction with no problem.
It’s usually more than enough, because even devices with IP44/IPX4 (or better) rating are meant to be used outside.
The only problem it would have if it was submerged in water or there was a constant stream of water flowing on it. For example: it’s not meant to be put under a gutter :grinning:
Do you have a specific lock model in mind?
