Arlo Doorbell & HomeKit Integration: My Experience & Solution
Hey everyone, I wanted to share my experience with integrating my Arlo Video Doorbell with HomeKit. I’ve been using Arlo for a while now, and it’s been a fantastic addition to my smart home setup. However, recently I decided to switch from connecting it directly via WiFi to using the Arlo Hub for HomeKit integration. I thought it would be a seamless process, but it turned out to be a bit of a puzzle!
The Setup
I have an Arlo Video Doorbell and the Arlo Hub. I followed the instructions to reconnect the doorbell via the hub instead of directly through WiFi. Everything seemed to be working fine in the Arlo app—I could see the doorbell, and it was responding to my commands. But when I checked the Home app on my iPhone, the doorbell wasn’t showing up. It was frustrating because I really wanted to use it with automations, like turning on my front lights when motion was detected.
The Problem
After some research, I realized that the issue might be related to how the Arlo Hub communicates with HomeKit. I checked the HomeKit section in the Arlo app, and all my cameras were listed except for the doorbell. I tried resetting the doorbell and the hub, but nothing changed. I even uninstalled and reinstalled the Arlo app, but the problem persisted.
The Solution
After reaching out to the Arlo support team and doing some digging in the community forums, I found that the issue was with the firmware on my Arlo Hub. It hadn’t been updated in a while, and the outdated firmware was causing compatibility issues with HomeKit. I updated the firmware through the Arlo app, and voilà! The doorbell appeared in the Home app, and everything started working as expected.
Tips for Others
If you’re having trouble integrating your Arlo devices with HomeKit, here are a few tips:
  • Check Firmware Updates: Make sure both your Arlo Hub and doorbell are running the latest firmware.
  • Reset and Reconnect: Sometimes, simply resetting the devices and reconnecting them can resolve the issue.
  • Check HomeKit Settings: Ensure that all devices are properly listed in the HomeKit section of the Arlo app.
While the process was a bit frustrating at first, it’s great to have my Arlo doorbell fully integrated with HomeKit. It adds a whole new layer of automation and convenience to my smart home setup. I’m now looking forward to experimenting with more complex automations!
If anyone else is struggling with similar issues, feel free to reach out. I’d be happy to share what I’ve learned!
Cheers,
