@AqaraOfficial Please can you help ?
Aqara LED Bulb T2 (fw 31) ignores a white colour-temperature command when it’s already showing a colour – all 12 of my bulbs do it
Setup: 12 × Aqara LED Bulb T2, firmware 31, paired to an Aqara hub and brought into Home Assistant through the hub’s Matter bridge. The bulbs report a supported colour-temperature range of 2000–9009K to Home Assistant. Automations are plain Home Assistant “Light: Turn on” actions – no scripts or templates. Every one of the 12 bulbs behaves the same way.
The problem
If a bulb is already lit in a colour (for example blue at 50%, which my alarm automation uses) and I then send “turn on, white 9000K, 100%”, the bulb does nothing. It stays blue. Home Assistant reports it as white, but looking at the actual bulb it is still blue.
So the automation does tell the bulb what to do at the end – the bulb just doesn’t accept the instruction when it’s currently showing a colour.
What I’ve found by testing (same result on all 12 bulbs)
- From blue, asking for 9000K – ignored, stays blue. Every time.
- From blue, asking for 6500K – switches to white straight away. Every time.
- From 6500K, asking for 9000K – works fine.
- Turning the bulb off and on again doesn’t help: the bulbs come back on in whatever colour they were last showing, so they just come back blue.
My guess at why
The bulb’s dedicated white LEDs only cover 2700K to 6500K. Anything cooler than that has to be mixed from the colour LEDs. It looks as though, when the bulb is already sitting on a colour and you ask for one of those “mixed” whites above 6500K, it simply drops the request – whereas 6500K is a “real” white it can always produce. Yet the bulb tells Home Assistant it supports up to 9009K, so a 9000K command ought to be accepted.
Workaround I’m using
Send 6500K at 100%, wait one second, then send 9000K at 100%. That works reliably on all of them, but it shouldn’t be necessary – a single “turn on, 9000K” ought to be enough.
Questions
- Is this a known issue on the T2 when going from an RGB colour to a colour temperature above 6500K?
- Is it the bulb firmware or the hub’s Matter bridge that’s dropping the command?
- Is a firmware update planned, or is there a hub/Matter setting that would make a direct 9000K command work?
Happy to run any tests you’d like and report back.
