Automatic laundry room lighting with a motion sensor
When I first started my smart home, I added a motion sensor and a smart bulb (both Aqara), connected through an Aqara Hub, in my laundry room, and it turned out to be one of the simplest but most useful things I set up.
The automation is basic: the light turns on when motion is detected, and turns off automatically after 15 minutes of no movement. That’s it — no complicated routines, no manual scheduling.
What surprised me was how much friction it removed from everyday life. I used to walk in with a laundry basket, fumble for the switch with my hands full, and forget to turn the light off half the time. Now I just walk in and the light is already on, and I never have to think about turning it off again.
My advice for beginners: don’t overlook small, “boring” spaces like laundry rooms, closets, or hallways when picking your first automation. They’re low-stakes (nothing bad happens if the timing isn’t perfect), cheap to set up, and the payoff in daily convenience is surprisingly high compared to more complex automations. It’s a great first project to learn the basics before tackling anything bigger.
The S10 switch has been great for my laundry room. It has the presence sensor built in and turns on and off. It is also able to control the lights, fan, and speakers with it’s 2 channels and programmable “button” (the screen).
I find this works well because it’s a smaller space. In a larger room it might not work as effectivey.
